跳转到主内容
LG Front Load Washing Machine Air Dome Replacement
你所需要的
  1. LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
  3. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Unclip the rear panel from the chassis.
  4. LG Front Load Washing Machine Air Dome Replacement: 步骤 4 中的图像 1,1
    • Remove the rear panel.
  5. LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: 步骤 5 中的图像 2,2
    • Pull the hose straight off the air dome hose to disconnect it.
  6. LG Front Load Washing Machine Air Dome Replacement, Unfasten the air dome: 步骤 6 中的图像 1,1
    • Remove the screw(s) securing the air dome.
  7. LG Front Load Washing Machine Air Dome Replacement: 步骤 7 中的图像 1,3 LG Front Load Washing Machine Air Dome Replacement: 步骤 7 中的图像 2,3 LG Front Load Washing Machine Air Dome Replacement: 步骤 7 中的图像 3,3
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  8. LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: 步骤 8 中的图像 2,2
    • Pull the air dome straight off its hose to remove it.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,500 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,640篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 66
总计 1,522
