跳转到主内容
LG Fortune Motherboard Replacement
你所需要的
  1. LG Fortune Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Fortune Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Motherboard Replacement: 步骤 2 中的图像 1,2 LG Fortune Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 LG Fortune Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 LG Fortune Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 9
总计 571
