跳转到主内容
LG Flatron W2241S Capacitors Replacement
你所需要的
  1. LG Flatron W2241S Capacitors Replacement, Opening the monitor: 步骤 1 中的图像 1,2 LG Flatron W2241S Capacitors Replacement, Opening the monitor: 步骤 1 中的图像 2,2
    • Use a spudger to remove the plastic basel around the display and remove any screws that you see on the back.
    • Carefully lift up the display assembly and set it aside.
  2. LG Flatron W2241S Capacitors Replacement, Reaching the main board: 步骤 2 中的图像 1,3 LG Flatron W2241S Capacitors Replacement, Reaching the main board: 步骤 2 中的图像 2,3 LG Flatron W2241S Capacitors Replacement, Reaching the main board: 步骤 2 中的图像 3,3
    • Lift up the metal bracket and carefully remove all connectors
  3. LG Flatron W2241S Capacitors Replacement, Finding the capacitors: 步骤 3 中的图像 1,2 LG Flatron W2241S Capacitors Replacement, Finding the capacitors: 步骤 3 中的图像 2,2
    • After you flip the metal bracket, it should look something like this.
    • Identify the faulty capacitors, remove them and solder new ones.
    • In my case, those marked in blue were busted and prevented the monitor from working.
    • For good measure I replaced all of them with brand new ones. It is a good idea that you do too.
结论
4等其他人完成本指南。
Simeon Brankov
于11/08/20注册
6,045 声望
创作了49篇指南
2条评论
This repair guide helped me fix my LG Flatron W2242T 22" computer monitor that powered off but would not power back on.
After making the repair, replacing bulging capacitors C203, C204, C205, and C212 with replacements of the same value, the monitor powered back on and works again!
richguard - 回复
Hello,
I am very glad to hear that my guide helped you!
Simeon Brankov -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 44
总计 1,175
