跳转到主内容
LG Flare Microphone Replacement
你所需要的
  1. LG Flare Microphone Replacement, Microphone: 步骤 1 中的图像 1,2 LG Flare Microphone Replacement, Microphone: 步骤 1 中的图像 2,2
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: 步骤 3 中的图像 1,1
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: 步骤 4 中的图像 1,1
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: 步骤 5 中的图像 1,1
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: 步骤 6 中的图像 1,1
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: 步骤 7 中的图像 1,1
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: 步骤 8 中的图像 1,2 LG Flare Microphone Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: 步骤 9 中的图像 1,1
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: 步骤 10 中的图像 1,1
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
结论
Kelsey Hanna
于09/29/15注册
1 声望
撰写一个指南
团队
Ohio State, Team 1-3, Garvin Fall 2015 Ohio State, Team 1-3, Garvin Fall 2015 的会员
OSU-GARVIN-F15S1G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 185
