跳转到主内容
LG Escape (p870) Rear Camera Replacement
你所需要的
  1. LG Escape (p870) Rear Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG Escape (p870) Rear Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Rear Camera Replacement: 步骤 2 中的图像 1,2 LG Escape (p870) Rear Camera Replacement: 步骤 2 中的图像 2,2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Rear Camera Replacement, Loudspeaker Assembly: 步骤 3 中的图像 1,1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Rear Camera Replacement: 步骤 4 中的图像 1,2 LG Escape (p870) Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) Rear Camera Replacement, Rear Camera: 步骤 5 中的图像 1,1
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) Rear Camera Replacement: 步骤 6 中的图像 1,3 LG Escape (p870) Rear Camera Replacement: 步骤 6 中的图像 2,3 LG Escape (p870) Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) Rear Camera Replacement: 步骤 7 中的图像 1,1
    • Use a plastic spudger or safe-open pry tool to release the camera's flex cable from its connector
    • Remove the camera from the housing and set it aside
结论
Brad
于08/12/12注册
1,908 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 447
