跳转到主内容
LG EnV Touch VX11000 Screen Assembly Replacement
你所需要的
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 3 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 3 中的图像 2,2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 步骤 4 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 步骤 4 中的图像 2,2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 5 中的图像 1,1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 6 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 步骤 7 中的图像 1,3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 步骤 7 中的图像 2,3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 步骤 7 中的图像 3,3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 8 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 8 中的图像 2,2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 9 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 9 中的图像 2,2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 11 中的图像 1,3 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 11 中的图像 2,3 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 11 中的图像 3,3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 12 中的图像 1,2 LG EnV Touch VX11000 Screen Assembly Replacement: 步骤 12 中的图像 2,2
    • Unplug the connector from the screen.
结论
3等其他人完成本指南。
Rachel Smith
于09/30/13注册
593 声望
创作了5篇指南
团队
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 1,101
