跳转到主内容
LG EnV Touch VX11000 Motherboard Replacement
你所需要的
  1. LG EnV Touch VX11000 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Motherboard Replacement: 步骤 3 中的图像 1,2 LG EnV Touch VX11000 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: 步骤 4 中的图像 1,2 LG EnV Touch VX11000 Motherboard Replacement, Volume and Camera Buttons: 步骤 4 中的图像 2,2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Motherboard Replacement: 步骤 6 中的图像 1,2 LG EnV Touch VX11000 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 LG EnV Touch VX11000 Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Use your fingers to pull up on the tab in order to unplug it.
  8. LG EnV Touch VX11000 Motherboard Replacement: 步骤 8 中的图像 1,2 LG EnV Touch VX11000 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using both of your hands, gently pry out the motherboard by pulling up on both ends.
结论
3等其他人完成本指南。
Rachel Smith
于09/30/13注册
593 声望
创作了5篇指南
团队
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 的会员
CPSU-FORTE-F13S13G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 14
总计 558
