当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lift the back plastic cover off by moving the opening tool around the edges of the phone.
Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
The side buttons may fall out when removing the back plastic.
Pull off the back plastic panel.
Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
Use the opening tool to lift up the green logic board in all areas and remove it.
The logic board may require some force to remove because it is taped to the plastic frame.
When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
