当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Lift the back plastic cover off by moving the opening tool around the edges of the phone.
Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
The side buttons may fall out when removing the back plastic.
Pull off the back plastic panel.
Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
Use the opening tool to lift up the green logic board in all areas and remove it.
The logic board may require some force to remove because it is taped to the plastic frame.
When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
Peel off the gold and green tape near the bottom of the phone.
Peel off the blue tape covering the speaker connector.
Peel off the gold tape to the left of the earpiece speaker.
It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
Undo the clips that attach the black plastic strip to the frame of the phone.
Pry the plastic strip away from the phone, using an opening tool, until it detaches.
Rotate the phone upside down with the back facing you.
Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
Do not detach the frame yet.
Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
Remove the frame from the plastic panel.
The next two steps are for earpiece removal only.
Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
It may be necessary to apply more force to remove the pad because it is taped to the frame.
Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
Remove the digitizer carefully without breaking the connector.
Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
