本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to install a new digitizer in your LG Dare.
你所需要的
Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
Peel off the gold and green tape near the bottom of the phone.
Peel off the blue tape covering the speaker connector.
Peel off the gold tape to the left of the earpiece speaker.
Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
Remove the digitizer carefully without breaking the connector.
To re-assemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
