跳转到主内容
LG Cosmos Side Case Replacement
你所需要的
  1. LG Cosmos Side Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Side Case Replacement: 步骤 2 中的图像 1,1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Side Case Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Side Case Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Side Case Replacement: 步骤 5 中的图像 1,1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Side Case Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Side Case Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Side Case Replacement: 步骤 8 中的图像 1,1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Side Case Replacement: 步骤 9 中的图像 1,1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Side Case Replacement: 步骤 10 中的图像 1,1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Side Case Replacement: 步骤 11 中的图像 1,1
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Side Case Replacement, Silicon Keypad: 步骤 12 中的图像 1,1
    • Lift the silicon keypad away from the rest of the phone.
  13. LG Cosmos Side Case Replacement, Side Case: 步骤 13 中的图像 1,1
    • Remove the four 2.0mm Phillips #000 screws on the golden squares.
  14. LG Cosmos Side Case Replacement: 步骤 14 中的图像 1,1
    • Slowly lift the side case away from the rest of the phone.
    • The flex cable can be torn if it is caught on the frame of the side case.
结论
Johnny Phane
于04/15/13注册
70 声望
创作了5篇指南
团队
Cal Poly, Team 13-63, Johann Spring 2013 Cal Poly, Team 13-63, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G63
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 13
总计 1,036
