跳转到主内容
LG Cosmos 2 Speaker Replacement
你所需要的
  1. LG Cosmos 2 Speaker Replacement, Battery: 步骤 1 中的图像 1,3 LG Cosmos 2 Speaker Replacement, Battery: 步骤 1 中的图像 2,3 LG Cosmos 2 Speaker Replacement, Battery: 步骤 1 中的图像 3,3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Speaker Replacement: 步骤 2 中的图像 1,3 LG Cosmos 2 Speaker Replacement: 步骤 2 中的图像 2,3 LG Cosmos 2 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Speaker Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Speaker Replacement: 步骤 4 中的图像 1,3 LG Cosmos 2 Speaker Replacement: 步骤 4 中的图像 2,3 LG Cosmos 2 Speaker Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 LG Cosmos 2 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
结论
Nick White
于10/18/13注册
851 声望
创作了8篇指南
团队
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G1
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 14
总计 357
