当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use the plastic opener to lift, and remove, the device battery.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use the plastic opener to pry the rear case loose.
This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
取消:我没有完成这个指南。
与7其他贡献者
于10/18/13注册
851 声望
创作了8篇指南
徽章: 9
+ 6更多徽章
CLEM-BENSON-F13S13G1
3 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 278
