跳转到主内容
LG Cosmos 2 Headphone Jack Replacement
你所需要的
  1. LG Cosmos 2 Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • First you will need to remove the back cover of the device.
    • You can do this with either a spudger or your fingers.
    • Carefully pry along the edges of the device until the cover pops off.
  2. LG Cosmos 2 Headphone Jack Replacement: 步骤 2 中的图像 1,2 LG Cosmos 2 Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Simply use the provided tab to lift the battery our of it's housing and set it aside.
  3. LG Cosmos 2 Headphone Jack Replacement: 步骤 3 中的图像 1,2 LG Cosmos 2 Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Use your screwdriver to gently unscrew the back part of the case.
    • Then use a spudger or your fingers to lift the case off of the motherboard housing.
  4. LG Cosmos 2 Headphone Jack Replacement: 步骤 4 中的图像 1,2 LG Cosmos 2 Headphone Jack Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to carefully detach the volume buttons.
    • The volume buttons are attached to a cable on the motherboard. Do not try and take them off completely.
  5. LG Cosmos 2 Headphone Jack Replacement: 步骤 5 中的图像 1,2 LG Cosmos 2 Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to carefully detach the camera button.
    • The camera button is attached to a cable on the motherboard. Do not try and take it off completely.
  6. LG Cosmos 2 Headphone Jack Replacement: 步骤 6 中的图像 1,2 LG Cosmos 2 Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Use a spudger or your finger to detach the motherboard from it's housing. Slowly pry along the edges to free it from the plastic grips that hold it in place.
    • There is a cable that connects the motherboard to the rest of the phone. Be careful when pulling the motherboard from it's housing so as not to disconnect it.
  7. LG Cosmos 2 Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Use a spudger to detach the small red and blue cable from the motherboard. Do this by slowly lifting up each side until it pops out of it's housing.
  8. LG Cosmos 2 Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Use your fingers to remove the black cover on the top of the motherboard. It simply pops off.
    • If you feel any resistance when trying to detach it, or it does not come off immediately, flip the motherboard over and detach the small plastic grips one by one.
  9. LG Cosmos 2 Headphone Jack Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • Carefully use a soldering iron to heat the bolts and then use a desoldering pump to pull the bolts out.
    • Then simply lift out the old headphone jack and fit in the new one.
    • During reassembly you need to fit in the new bolts and carefully solder them back in so as not to damage the motherboard.
结论
Henry Switala
于06/01/16注册
101 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 130
