跳转到主内容
加入维修社区 - 创建账户
LG Cosmos 2 Front Keyboard Replacement
你所需要的
  1. LG Cosmos 2 Front Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 LG Cosmos 2 Front Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 LG Cosmos 2 Front Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Front Keyboard Replacement: 步骤 2 中的图像 1,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 2 中的图像 2,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Front Keyboard Replacement, Rear Case: 步骤 3 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Front Keyboard Replacement: 步骤 4 中的图像 1,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 4 中的图像 2,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Front Keyboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Front Keyboard Replacement: 步骤 6 中的图像 1,1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Front Keyboard Replacement: 步骤 7 中的图像 1,2 LG Cosmos 2 Front Keyboard Replacement: 步骤 7 中的图像 2,2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Front Keyboard Replacement: 步骤 8 中的图像 1,2 LG Cosmos 2 Front Keyboard Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Front Keyboard Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 Front Keyboard Replacement, Option Buttons: 步骤 10 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 Front Keyboard Replacement: 步骤 11 中的图像 1,2 LG Cosmos 2 Front Keyboard Replacement: 步骤 11 中的图像 2,2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 Front Keyboard Replacement: 步骤 12 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 Front Keyboard Replacement: 步骤 13 中的图像 1,2 LG Cosmos 2 Front Keyboard Replacement: 步骤 13 中的图像 2,2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 Front Keyboard Replacement: 步骤 14 中的图像 1,1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 Front Keyboard Replacement: 步骤 15 中的图像 1,1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 Front Keyboard Replacement: 步骤 16 中的图像 1,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 16 中的图像 2,3 LG Cosmos 2 Front Keyboard Replacement: 步骤 16 中的图像 3,3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 Front Keyboard Replacement: 步骤 17 中的图像 1,1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: 步骤 18 中的图像 1,2 LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: 步骤 18 中的图像 2,2
    • Use a tool to pry open the LCD display. Remove the display and the motherboard-looking device that it's connected to.
  19. LG Cosmos 2 Front Keyboard Replacement: 步骤 19 中的图像 1,1
    • Rotate and remove the keypad from the front case.
结论
Nick White
于10/18/13注册
866 声望
创作了8篇指南
团队
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 的会员
CLEM-BENSON-F13S13G1
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 802
