跳转到主内容
LG Chocolate Side Buttons Replacement
你所需要的
  1. LG Chocolate Side Buttons Replacement, Battery: 步骤 1 中的图像 1,2 LG Chocolate Side Buttons Replacement, Battery: 步骤 1 中的图像 2,2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Side Buttons Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Side Buttons Replacement: 步骤 3 中的图像 1,3 LG Chocolate Side Buttons Replacement: 步骤 3 中的图像 2,3 LG Chocolate Side Buttons Replacement: 步骤 3 中的图像 3,3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Side Buttons Replacement, Sliding Front: 步骤 4 中的图像 1,1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Side Buttons Replacement: 步骤 5 中的图像 1,2 LG Chocolate Side Buttons Replacement: 步骤 5 中的图像 2,2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Side Buttons Replacement: 步骤 6 中的图像 1,2 LG Chocolate Side Buttons Replacement: 步骤 6 中的图像 2,2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Side Buttons Replacement: 步骤 7 中的图像 1,1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Side Buttons Replacement, LCD Board: 步骤 8 中的图像 1,3 LG Chocolate Side Buttons Replacement, LCD Board: 步骤 8 中的图像 2,3 LG Chocolate Side Buttons Replacement, LCD Board: 步骤 8 中的图像 3,3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Side Buttons Replacement: 步骤 9 中的图像 1,2 LG Chocolate Side Buttons Replacement: 步骤 9 中的图像 2,2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Side Buttons Replacement: 步骤 10 中的图像 1,1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Side Buttons Replacement: 步骤 11 中的图像 1,1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Side Buttons Replacement: 步骤 12 中的图像 1,2 LG Chocolate Side Buttons Replacement: 步骤 12 中的图像 2,2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Side Buttons Replacement, Side Buttons: 步骤 13 中的图像 1,1
    • The side buttons can now be accessed freely.
结论
Charles Yoon
于01/18/13注册
64 声望
创作了2篇指南
团队
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G46
4 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 190
