跳转到主内容
LG Chocolate Motherboard Replacement
你所需要的
  1. LG Chocolate Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Chocolate Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Motherboard Replacement, Back Cover: 步骤 2 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Motherboard Replacement: 步骤 3 中的图像 1,3 LG Chocolate Motherboard Replacement: 步骤 3 中的图像 2,3 LG Chocolate Motherboard Replacement: 步骤 3 中的图像 3,3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,2 LG Chocolate Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Carefully pry the motherboard off of the back case
结论
Maci Miri
于01/18/13注册
39 声望
创作了3篇指南
团队
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G46
4 名成员
创作了22篇指南
一条评论
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 822
