跳转到主内容
加入维修社区 - 创建账户
LG Chocolate Camera Replacement
你所需要的
  1. LG Chocolate Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG Chocolate Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Camera Replacement, Back Cover: 步骤 2 中的图像 1,1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Camera Replacement: 步骤 3 中的图像 1,3 LG Chocolate Camera Replacement: 步骤 3 中的图像 2,3 LG Chocolate Camera Replacement: 步骤 3 中的图像 3,3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
  4. LG Chocolate Camera Replacement, Sliding Front: 步骤 4 中的图像 1,1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Camera Replacement: 步骤 5 中的图像 1,2 LG Chocolate Camera Replacement: 步骤 5 中的图像 2,2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Camera Replacement: 步骤 6 中的图像 1,2 LG Chocolate Camera Replacement: 步骤 6 中的图像 2,2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Camera Replacement: 步骤 7 中的图像 1,1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Camera Replacement, Camera: 步骤 8 中的图像 1,1
    • Carefully pry the connecting cable between the camera and the motherboard off of the board.
  9. LG Chocolate Camera Replacement: 步骤 9 中的图像 1,2 LG Chocolate Camera Replacement: 步骤 9 中的图像 2,2
    • Using a small screwdriver, carefully pry the camera out of its position.
    • The camera will seem stuck to the board because of its tape. Don't be afraid to pry it.
结论
Thomas
于01/18/13注册
91 声望
创作了4篇指南
团队
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G46
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 384
