跳转到主内容
加入维修社区 - 创建账户
LG Chocolate Back Cover Replacement
你所需要的
  1. LG Chocolate Back Cover Replacement, Battery: 步骤 1 中的图像 1,2 LG Chocolate Back Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Back Cover Replacement, Back Cover: 步骤 2 中的图像 1,1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Back Cover Replacement: 步骤 3 中的图像 1,3 LG Chocolate Back Cover Replacement: 步骤 3 中的图像 2,3 LG Chocolate Back Cover Replacement: 步骤 3 中的图像 3,3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
团队
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 的会员
CPSU-REGAN-W13S19G46
4 名成员
创作了22篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 49
总计 597
