跳转到主内容
LG Chocolate 3 Display Connector Replacement
你所需要的
  1. LG Chocolate 3 Display Connector Replacement, Display Connector: 步骤 1 中的图像 1,1
    • Remove the battery and expose the motherboard following the General Disassembly LG VX8560. You will have to replace the side keys once finished with this guide.
    • Locate intertwined blue and red wire (screen display connector.)
  2. LG Chocolate 3 Display Connector Replacement: 步骤 2 中的图像 1,1
    • (Ignore this step if the screen display connector is already separated from the motherboard) Using the spudger, place the pointy end between the plastic end of the wire and the motherboard and lift/push wire from the motherboard socket. You should see two golden pins protruding from the plastic.
    • Align the two golden pins at the end of the wire with its respective socket on the motherboard and gently push down until you hear a click-sound.
    • To reassemble your device, follow Side Keys Installation in reverse order.
终点
Mitchel
于04/18/13注册
1 声望
撰写一个指南
团队
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 的会员
CPSU-JOHANN-S13S13G62
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 321
