跳转到主内容
LG CU515 SKU 64743 Device SIM Card Replacement
你所需要的
  1. LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: 步骤 1 中的图像 1,3 LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: 步骤 1 中的图像 2,3 LG CU515 SKU 64743 Device SIM Card Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Locate the raised tab at the top of the back cover.
    • Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone.
    • Slide the cover down until it is completely removed from the phone.
  2. 注意:步骤 2 源自标记为进行中的 指南
    LG CU515 SKU 64743 Device SIM Card Replacement, Battery: 步骤 2 中的图像 1,3 LG CU515 SKU 64743 Device SIM Card Replacement, Battery: 步骤 2 中的图像 2,3 LG CU515 SKU 64743 Device SIM Card Replacement, Battery: 步骤 2 中的图像 3,3
    • Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
  3. LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,3 LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: 步骤 3 中的图像 2,3 LG CU515 SKU 64743 Device SIM Card Replacement, SIM Card: 步骤 3 中的图像 3,3
    • Holding the phone in one hand and using your thumb on your other hand, push the SIM card towards the bottom of the phone and out from under the metal retaining clip holding it in place. It should slide out relatively easy.
结论
Josh Davis
于10/18/13注册
301 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 349
