跳转到主内容
LG CU515 SKU 64743 Device Camera Lens Replacement
你所需要的
  1. 注意:步骤 1-5 源自标记为进行中的 指南
    LG CU515 SKU 64743 Device Camera Lens Replacement, Front Cover: 步骤 1 中的图像 1,2 LG CU515 SKU 64743 Device Camera Lens Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Separate the top half of the clamshell from the bottom half by first locating the two hinges.
    • Carefully pull to one side and immediately up. The top part should pop out of the hinge. Next slide the opposite direction to pull out of the other hinge.
    • This will take a lot of force, so be careful not to break the plastic hinge.
  2. LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 2 中的图像 1,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 2 中的图像 2,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 2 中的图像 3,3
    • Locate the two small circles located at the bottom left and right corners of the main screen.
    • Remove the two small rubber dots covering the screw heads using the tweezers.
    • The sharp ends of the tweezers can be stuck into the rubber dots in order to remove them.
  3. LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 3 中的图像 1,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 3 中的图像 2,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 3 中的图像 3,3
    • Locate the rubber strip found above the main screen. Use the pry bar to remove the rubber strip. This exposes the screws in the upper left and right hand corner.
  4. LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 4 中的图像 1,2 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 4 中的图像 2,2
    • Use the small Phillips-head screwdriver to remove four 3mm screws exposed during steps 1 and 2.
  5. LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 5 中的图像 1,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 5 中的图像 2,3 LG CU515 SKU 64743 Device Camera Lens Replacement: 步骤 5 中的图像 3,3
    • Using the pry bar, remove the front cover of the phone.
    • It may be necessary to run the pry bar along the length of the perimeter to separate the front cover from the rest of the phone.
    • Once loose, the front cover should easily be pulled away from the phone, as shown in the second picture.
  6. LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 1,3 LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 2,3 LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 步骤 6 中的图像 3,3
    • Rotate the phone 180 degrees and locate the small black square shown in the photo. Using the tweezers, pinch the raised circular lens casing and remove.
结论
Maggie
于10/18/13注册
680 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 287
