跳转到主内容
LG CG225 Motherboard Replacement
你所需要的
  1. LG CG225 Motherboard Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using a small plastic opening tool, remove the motherboard.
结论
Darlena
于02/11/14注册
219 声望
创作了3篇指南
团队
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G2
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 139
