跳转到主内容
LG CG225 Keyboard Replacement
你所需要的
  1. LG CG225 Keyboard Replacement, Rear Cover: 步骤 1 中的图像 1,1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Keyboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using a small plastic opening tool, remove the motherboard.
  6. LG CG225 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
结论
Mackenzie
于02/13/14注册
1 声望
创作了2篇指南
团队
Ohio State, Team 1-3, Meza Spring 2014 Ohio State, Team 1-3, Meza Spring 2014 的会员
OSU-MEZA-S14S1G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 274
