当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Power down the cell phone by pressing and holding down the red "end call" button.
Turn the phone screen-down so you are looking at the back cover.
Slide the back cover down using your finger to remove the cover from the phone.
Place your finger at the top of the battery in small gap.
Press downward while pulling outward to remove the battery.
Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
Insert a plastic opening tool in the seam.
Run the tool along the seam to release all the tabs.
Pull the phone back cover off once all the tabs are released.
Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
The hardshell case is separated from the rest of the phone.
取消:我没有完成这个指南。
与4其他贡献者
于01/25/10注册
1 声望
撰写一个指南
徽章: 8
+ 5更多徽章
CPSU-REGAN-W10S14G42
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 1,769
