跳转到主内容
LG CG180 Circuit Board Replacement
你所需要的
  1. LG CG180 Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Circuit Board Replacement: 步骤 3 中的图像 1,2 LG CG180 Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Circuit Board Replacement, Hardshell Case: 步骤 6 中的图像 1,1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Circuit Board Replacement: 步骤 8 中的图像 1,2 LG CG180 Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Circuit Board Replacement: 步骤 9 中的图像 1,2 LG CG180 Circuit Board Replacement: 步骤 9 中的图像 2,2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Circuit Board Replacement: 步骤 10 中的图像 1,1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Circuit Board Replacement: 步骤 11 中的图像 1,1
    • The hardshell case is separated from the rest of the phone.
  12. LG CG180 Circuit Board Replacement, Keypad: 步骤 12 中的图像 1,2 LG CG180 Circuit Board Replacement, Keypad: 步骤 12 中的图像 2,2
    • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  13. LG CG180 Circuit Board Replacement, Display: 步骤 13 中的图像 1,1
    • Place the circuit board with the display facing downward.
  14. LG CG180 Circuit Board Replacement: 步骤 14 中的图像 1,1
    • Use thumb to release both white clips at the top of the circuit board.
    • Be careful with the display because it is still attached by electrical tape.
  15. LG CG180 Circuit Board Replacement: 步骤 15 中的图像 1,2 LG CG180 Circuit Board Replacement: 步骤 15 中的图像 2,2
    • Once both clips are released, turn over the circuit board so that the display is facing upward.
    • Carefully lift the display from the left side and open to the right.
  16. LG CG180 Circuit Board Replacement: 步骤 16 中的图像 1,1
    • Carefully remove the electrical tape from the display.
  17. LG CG180 Circuit Board Replacement: 步骤 17 中的图像 1,1
    • The display is disconnected from the circuit board.
  18. LG CG180 Circuit Board Replacement, Circuit Board: 步骤 18 中的图像 1,1
    • The circuit board is separated from the rest of the phone.
结论
Alex Jacobs
于01/21/10注册
5 声望
创作了4篇指南
团队
Cal Poly, Team 14-42, Regan Winter 2010 Cal Poly, Team 14-42, Regan Winter 2010 的会员
CPSU-REGAN-W10S14G42
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 2,828
