跳转到主内容
LG CF360 Sliding Mechanism Replacement
你所需要的
  1. LG CF360 Sliding Mechanism Replacement, Battery: 步骤 1 中的图像 1,2 LG CF360 Sliding Mechanism Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Sliding Mechanism Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery.
  3. LG CF360 Sliding Mechanism Replacement, Back Cover: 步骤 3 中的图像 1,2 LG CF360 Sliding Mechanism Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Sliding Mechanism Replacement: 步骤 4 中的图像 1,1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Sliding Mechanism Replacement: 步骤 5 中的图像 1,3 LG CF360 Sliding Mechanism Replacement: 步骤 5 中的图像 2,3 LG CF360 Sliding Mechanism Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Sliding Mechanism Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Sliding Mechanism Replacement, Motherboard: 步骤 7 中的图像 1,2 LG CF360 Sliding Mechanism Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
    • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
  8. LG CF360 Sliding Mechanism Replacement: 步骤 8 中的图像 1,1
    • Gently remove the blue transparent tape from the connector.
  9. LG CF360 Sliding Mechanism Replacement: 步骤 9 中的图像 1,1
    • With the plastic opening tool, gently pry the LCD connector from the motherboard.
    • Set the motherboard aside.
  10. LG CF360 Sliding Mechanism Replacement, Front Case: 步骤 10 中的图像 1,1
    • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
  11. LG CF360 Sliding Mechanism Replacement: 步骤 11 中的图像 1,1
    • Gently pull the orange ribbon from the number pad casing.
    • Set the number pad case to the side once it is detached from the ribbon.
  12. LG CF360 Sliding Mechanism Replacement: 步骤 12 中的图像 1,1
    • Remove the two red sticker screw coverings at the top corners with tweezers.
  13. LG CF360 Sliding Mechanism Replacement: 步骤 13 中的图像 1,1
    • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
  14. LG CF360 Sliding Mechanism Replacement: 步骤 14 中的图像 1,2 LG CF360 Sliding Mechanism Replacement: 步骤 14 中的图像 2,2
    • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
    • Set the red sliding backing and front cover to the side.
  15. LG CF360 Sliding Mechanism Replacement, Sliding Mechanism: 步骤 15 中的图像 1,1
    • Unscrew the eight Phillips #000 (1mm) screws on the back side of where the sliding mechanism is located.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G27
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 10
总计 357
