跳转到主内容
LG CF360 Rear Speaker Replacement
你所需要的
  1. LG CF360 Rear Speaker Replacement, Battery: 步骤 1 中的图像 1,2 LG CF360 Rear Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: 步骤 3 中的图像 1,2 LG CF360 Rear Speaker Replacement, Back Cover: 步骤 3 中的图像 2,2
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: 步骤 5 中的图像 1,3 LG CF360 Rear Speaker Replacement: 步骤 5 中的图像 2,3 LG CF360 Rear Speaker Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to pry the speaker out of the back cover.
结论
另外一个人完成了本指南。
Annie White
于10/18/13注册
262 声望
创作了2篇指南
团队
Cal Poly, Team 4-27, Amido Fall 2013 Cal Poly, Team 4-27, Amido Fall 2013 的会员
CPSU-AMIDO-F13S4G27
4 名成员
创作了19篇指南
一条评论
Where can I buy the replacement parts?
Sarah Birkett - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 259
