跳转到主内容
LG Aristo Screen Replacement
你所需要的
  1. LG Aristo Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Turn off the device and make sure you are working on a flat, lit surface.
  2. LG Aristo Screen Replacement: 步骤 2 中的图像 1,2 LG Aristo Screen Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to pry off the back case.
  3. LG Aristo Screen Replacement: 步骤 3 中的图像 1,3 LG Aristo Screen Replacement: 步骤 3 中的图像 2,3 LG Aristo Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the SD and SIM cards by sliding the cards out with your finger.
  4. LG Aristo Screen Replacement: 步骤 4 中的图像 1,3 LG Aristo Screen Replacement: 步骤 4 中的图像 2,3 LG Aristo Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
  5. LG Aristo Screen Replacement: 步骤 5 中的图像 1,2 LG Aristo Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
  6. LG Aristo Screen Replacement: 步骤 6 中的图像 1,2 LG Aristo Screen Replacement: 步骤 6 中的图像 2,2
    • Pry up on the screen with a plastic opening tool.
    • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
  7. LG Aristo Screen Replacement: 步骤 7 中的图像 1,2 LG Aristo Screen Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Detach the cables from the press fit connectors.
    • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
    • You can lift them up with you finger or you can use tweezers (optional).
  8. LG Aristo Screen Replacement: 步骤 8 中的图像 1,2 LG Aristo Screen Replacement: 步骤 8 中的图像 2,2
    • Gently remove the motherboard.
  9. LG Aristo Screen Replacement: 步骤 9 中的图像 1,1
    • Replace the screen.
结论
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
2等其他人完成本指南。
团队
Gateway, Team S1-G5, Saknee Fall 2019 Gateway, Team S1-G5, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G5
4 名成员
创作了1篇指南
一条评论
Do i need Loca Glue to replace the outer Glass?
chuck - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 1,332
