跳转到主内容
LG Aristo MS210 Front and Rear Camera Replacement
你所需要的
  1. LG Aristo MS210 Front and Rear Camera Replacement, Battery: 步骤 1 中的图像 1,3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: 步骤 1 中的图像 2,3 LG Aristo MS210 Front and Rear Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Insert the spudger into the notch on the bottom left side of the phone.
    • Apply light pressure to remove the back cover.
  2. LG Aristo MS210 Front and Rear Camera Replacement: 步骤 2 中的图像 1,2 LG Aristo MS210 Front and Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Insert the spudger into the notch located on the bottom middle of the battery.
    • Apply light pressure to remove the battery.
  3. LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 步骤 3 中的图像 1,3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 步骤 3 中的图像 2,3 LG Aristo MS210 Front and Rear Camera Replacement, Command Button: 步骤 3 中的图像 3,3
    • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
    • Use the spudger to remove the inner shell.
    • Flip the inner shell over to expose the clips holding the command button.
  4. LG Aristo MS210 Front and Rear Camera Replacement: 步骤 4 中的图像 1,3 LG Aristo MS210 Front and Rear Camera Replacement: 步骤 4 中的图像 2,3 LG Aristo MS210 Front and Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Use the spudger disconnect the three clips holding in the command button as highlighted.
    • Remove the command button.
  5. LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 5 中的图像 1,3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 5 中的图像 2,3 LG Aristo MS210 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 5 中的图像 3,3
    • Use the spudger to disconnect the ZIF connector securing the front-facing camera.
  6. LG Aristo MS210 Front and Rear Camera Replacement: 步骤 6 中的图像 1,3 LG Aristo MS210 Front and Rear Camera Replacement: 步骤 6 中的图像 2,3 LG Aristo MS210 Front and Rear Camera Replacement: 步骤 6 中的图像 3,3
    • Use the spudger disconnect the ZIF connector securing the back-facing camera.
  7. LG Aristo MS210 Front and Rear Camera Replacement: 步骤 7 中的图像 1,1
    • Remove both the front and back facing cameras.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 158
