跳转到主内容
LG Ally VS740 Camera Flash Replacement
你所需要的
  1. LG Ally VS740 Camera Flash Replacement, Camera Flash: 步骤 1 中的图像 1,1
    • Hold phone in hand, then flip to battery pack
    • Take off battery cover
  2. LG Ally VS740 Camera Flash Replacement: 步骤 2 中的图像 1,1
    • Remove battery
    • Locate the six surrounding screws located on the edge of the inner compartment, including the two screws on the metal piece where the battery was once placed.
  3. LG Ally VS740 Camera Flash Replacement: 步骤 3 中的图像 1,1
    • Slide the phone open. Notice on the edges around the keyboard, there is a thick casing. Remove this casing, instructions below…
    • Placing two dominant fingers on the back plate where the battery was, use your thumb finger nail (or prying utensil) and place it on the edge of this thin casing. Firmly, push down with your finger nail (prying utensil) around the casing from left to right. Disconnect casing from keyboard section. Flip the phone over and remove it.
  4. LG Ally VS740 Camera Flash Replacement: 步骤 4 中的图像 1,2 LG Ally VS740 Camera Flash Replacement: 步骤 4 中的图像 2,2
    • Using your prying tool, lift the green circuit board platform off the black casing and gently disconnect the connection point between the tether and the green circuit board.
    • Flip phone over, and notice where the camera lies on the other side, there are three small clips connecting a black casing over the section of the phone. Gently using your hands or the prying tool, take these clips off.
  5. LG Ally VS740 Camera Flash Replacement: 步骤 5 中的图像 1,1
    • The white rectangle with the yellow square is the flash. Gently lift up and disconnect flash module. Take your new flash and aligning the connection point to the connection hole, push it down firmly until it is snug in place. Follow the steps backwards to put phone back together.
结论
另外一个人完成了本指南。
Billy Carias
于10/23/14注册
213 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 357
