跳转到主内容
LG A275 Vibrator Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    LG A275 Vibrator Replacement, Battery: 步骤 1 中的图像 1,2 LG A275 Vibrator Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone upside down so that the bottom of the back is facing you.
  2. LG A275 Vibrator Replacement, Remove cover: 步骤 2 中的图像 1,2 LG A275 Vibrator Replacement, Remove cover: 步骤 2 中的图像 2,2
    • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
  3. LG A275 Vibrator Replacement: 步骤 3 中的图像 1,1
    • Gently remove the battery from the device.
  4. LG A275 Vibrator Replacement, Vibrator: 步骤 4 中的图像 1,3 LG A275 Vibrator Replacement, Vibrator: 步骤 4 中的图像 2,3 LG A275 Vibrator Replacement, Vibrator: 步骤 4 中的图像 3,3
    • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
    • Be careful when using the plastic opening tool not to brute force the phone open, the plastics are fragile.
  5. LG A275 Vibrator Replacement: 步骤 5 中的图像 1,2 LG A275 Vibrator Replacement: 步骤 5 中的图像 2,2
    • After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
结论
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
Nathanael Knight
于03/27/18注册
181 声望
创作了2篇指南
团队
IUPUI, Team S3-G1, Harley Spring 2018 IUPUI, Team S3-G1, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S3G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 11
总计 127
