简介
In this guide, you will see how to take apart the LG-A275 in order to replace the phone's vibrator.
你所需要的
步骤 1 Battery
注意:步骤 1-3 源自标记为进行中的 指南。
Turn the phone upside down so that the bottom of the back is facing you.
Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
