跳转到主内容
LG 440G Keypad Replacement
你所需要的
  1. LG 440G Keypad Replacement, Turn off phone.: 步骤 1 中的图像 1,1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Keypad Replacement, Flip phone.: 步骤 2 中的图像 1,1
    • Flip the phone over.
  3. LG 440G Keypad Replacement, Rear cover removal.: 步骤 3 中的图像 1,1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Keypad Replacement, Removal of battery.: 步骤 4 中的图像 1,1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. LG 440G Keypad Replacement, Unscrew six screws along edges of casing: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. LG 440G Keypad Replacement, Lift casing cover: 步骤 6 中的图像 1,2 LG 440G Keypad Replacement, Lift casing cover: 步骤 6 中的图像 2,2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
  7. LG 440G Keypad Replacement, Remove rectangular piece (with orange tape attached): 步骤 7 中的图像 1,2 LG 440G Keypad Replacement, Remove rectangular piece (with orange tape attached): 步骤 7 中的图像 2,2
    • Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
  8. LG 440G Keypad Replacement, Dislodge logic board: 步骤 8 中的图像 1,1
    • Dislodge the logic board using a plastic opening tool.
  9. LG 440G Keypad Replacement, Lift logic board out: 步骤 9 中的图像 1,1
    • Remove the logic board by lifting up.
  10. LG 440G Keypad Replacement, Lift keypad out of casing: 步骤 10 中的图像 1,1
    • Remove the keypad from the phone by pushing the keypad itself out from the front of the phone. Then, lift the keypad out of the casing to separate the keypad from the casing.
结论
JP Belanger
于02/17/15注册
225 声望
创作了2篇指南
团队
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015 的会员
OSU-BUEHL-W15S1G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 627
