跳转到主内容
加入维修社区 - 创建账户
LG 440G Bottom Casing Replacement
你所需要的
  1. LG 440G Bottom Casing Replacement, Turn off phone.: 步骤 1 中的图像 1,1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Bottom Casing Replacement, Flip phone.: 步骤 2 中的图像 1,1
    • Flip the phone over.
  3. LG 440G Bottom Casing Replacement, Rear cover removal.: 步骤 3 中的图像 1,1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Bottom Casing Replacement, Removal of battery.: 步骤 4 中的图像 1,1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. LG 440G Bottom Casing Replacement, Unscrew six screws along edges of casing: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. LG 440G Bottom Casing Replacement, Lift casing cover: 步骤 6 中的图像 1,2 LG 440G Bottom Casing Replacement, Lift casing cover: 步骤 6 中的图像 2,2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
结论
Emily Class
于02/17/15注册
107 声望
撰写一个指南
团队
Ohio State, Team 1-1, Buehl Winter 2015 Ohio State, Team 1-1, Buehl Winter 2015 的会员
OSU-BUEHL-W15S1G1
4 名成员
创作了8篇指南
1指南评论
this would be most probably, the same guide to tear down the LG B470
douglas flores - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 1,869
