跳转到主内容
LG 32CS560 Power Supply Board Replacement
你所需要的
  1. LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: 步骤 1 中的图像 1,2 LG 32CS560 Power Supply Board Replacement, Prepare your LG 32CS560 for disassembly: 步骤 1 中的图像 2,2
    • Lay the TV face down on a soft surface
    • Remove the base of the TV by unscrewing the 4 base screws.
    • There is no base on the picture, the position of the base is marked whit the red box.
  2. LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: 步骤 2 中的图像 1,2 LG 32CS560 Power Supply Board Replacement, Disassemble the LG32CS560: 步骤 2 中的图像 2,2
    • Remove the 15 Phillips head screws on the back of the TV.
    • Carefully remove the black plastic back panel of the TV to expose the electronics inside
  3. LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 步骤 3 中的图像 1,3 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 步骤 3 中的图像 2,3 LG 32CS560 Power Supply Board Replacement, Disconnect & Remove the Bad Power Supply Board: 步骤 3 中的图像 3,3
    • Carefully disconnect the three wire bundles attached to the power supply.
    • Remove the four screws holding the power supply in place.
    • Now you can lift out the Power Supply Board.
    • If the black cylindrical component marked with yellow seems to have expanded or is leaking liquid or goo, then the power supply board is definitely bad.
结论
19等其他人完成本指南。
团队
USF Tampa, Team 1-3, Donnelly Fall 2014 USF Tampa, Team 1-3, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G3
1 名成员
创作了1篇指南
一条评论
preciso duma destas power bord como fazer para ter
brun mendes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 33
过去 30 天: 181
总计 44,625
