跳转到主内容
LG 305C Speaker Replacement
你所需要的
  1. LG 305C Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Speaker Replacement: 步骤 2 中的图像 1,1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Speaker Replacement, Internal Casing: 步骤 3 中的图像 1,1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Speaker Replacement: 步骤 4 中的图像 1,1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Speaker Replacement: 步骤 6 中的图像 1,1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  7. LG 305C Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • Insert plastic opening tool under the plastic flap and lift the speaker out.
结论
另外一个人完成了本指南。
团队
IUPUI, Team S6-G1, Baechle Spring 2018 IUPUI, Team S6-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 129
