跳转到主内容
加入维修社区 - 创建账户
LG 305C Internal Casing Replacement
你所需要的
  1. LG 305C Internal Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
  2. LG 305C Internal Casing Replacement: 步骤 2 中的图像 1,1
    • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
  3. LG 305C Internal Casing Replacement, Internal Casing: 步骤 3 中的图像 1,1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  4. LG 305C Internal Casing Replacement: 步骤 4 中的图像 1,1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  5. LG 305C Internal Casing Replacement: 步骤 5 中的图像 1,1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  6. LG 305C Internal Casing Replacement: 步骤 6 中的图像 1,1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
结论
Ashley Kidwell
于03/20/18注册
454 声望
创作了5篇指南
团队
IUPUI, Team S6-G1, Baechle Spring 2018 IUPUI, Team S6-G1, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S6G1
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 216
