跳转到主内容
LG 1010 LCD Screen Replacement
你所需要的
  1. LG 1010 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: 步骤 2 中的图像 1,2 LG 1010 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: 步骤 3 中的图像 1,3 LG 1010 LCD Screen Replacement: 步骤 3 中的图像 2,3 LG 1010 LCD Screen Replacement: 步骤 3 中的图像 3,3
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: 步骤 4 中的图像 1,2 LG 1010 LCD Screen Replacement, Front  Cover: 步骤 4 中的图像 2,2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: 步骤 6 中的图像 1,2 LG 1010 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: 步骤 10 中的图像 1,2 LG 1010 LCD Screen Replacement, Back Cover: 步骤 10 中的图像 2,2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: 步骤 11 中的图像 1,2 LG 1010 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: 步骤 12 中的图像 1,1
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: 步骤 14 中的图像 1,1
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: 步骤 15 中的图像 1,2 LG 1010 LCD Screen Replacement: 步骤 15 中的图像 2,2
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: 步骤 16 中的图像 1,2 LG 1010 LCD Screen Replacement: 步骤 16 中的图像 2,2
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 949
