跳转到主内容
LG 1010 Front Cover Replacement
你所需要的
  1. LG 1010 Front Cover Replacement, Front  Cover: 步骤 1 中的图像 1,2 LG 1010 Front Cover Replacement, Front  Cover: 步骤 1 中的图像 2,2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  2. LG 1010 Front Cover Replacement: 步骤 2 中的图像 1,1
    • Remove two screws using a Torx T6 screwdriver.
  3. LG 1010 Front Cover Replacement: 步骤 3 中的图像 1,2 LG 1010 Front Cover Replacement: 步骤 3 中的图像 2,2
    • Pry off the screen front cover with a small flathead screwdriver.
  4. LG 1010 Front Cover Replacement: 步骤 4 中的图像 1,1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  5. LG 1010 Front Cover Replacement: 步骤 5 中的图像 1,1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  6. LG 1010 Front Cover Replacement: 步骤 6 中的图像 1,1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 3-25, Regan Fall 2010 Cal Poly, Team 3-25, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G25
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,022
