跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Flashlight,应参考我们的维修指南
  1. LED touch light Teardown, LED touch light Teardown: 步骤 1 中的图像 1,1
    • The assembled light.
  2. LED touch light Teardown: 步骤 2 中的图像 1,1
    • Twist the mounting plate clockwise, then lift to remove it.
  3. LED touch light Teardown: 步骤 3 中的图像 1,1
    • Remove the three AAA batteries from their holders.
  4. LED touch light Teardown: 步骤 4 中的图像 1,1
    • Loosen and remove the four Phillips screws.
  5. LED touch light Teardown: 步骤 5 中的图像 1,1
    • Having removed the four Phillips screws in the previous step, separate the assembly as shown.
  6. LED touch light Teardown: 步骤 6 中的图像 1,1
    • Remove the three springs.
  7. LED touch light Teardown: 步骤 7 中的图像 1,1
    • Using the craft knife, prise and loosen the three tabs shown from their mounting points. This will make removing the battery contacts easier in the next step.
  8. LED touch light Teardown: 步骤 8 中的图像 1,1
    • Remove the battery contacts from their mounts, taking care to separate the soldered electrical wires without damaging nearby parts. Note the two smaller contacts which connect to the circuit board.
  9. LED touch light Teardown: 步骤 9 中的图像 1,1
    • Using the craft knife, slice off the black plastic extrusions at the indicated positions. These tabs secure the circuit board to the main assembly.
  10. LED touch light Teardown: 步骤 10 中的图像 1,1
    • Lift and separate the power switch from the main assembly.
  11. LED touch light Teardown: 步骤 11 中的图像 1,1
    • Using a similar technique to that exercised in step 9, slice off the clear plastic extrusions at the indicated positions. These extrusions secure the lens, case and reflector elements.
  12. LED touch light Teardown: 步骤 12 中的图像 1,1
    • The separated lens, case and reflector elements.
  13. LED touch light Teardown: 步骤 13 中的图像 1,1
    • The full assortment of separated parts.
Vimal
于07/21/13注册
219 声望
撰写一个指南
3指南评论
LED Flashlight is the best ever app i have ever use...I love it..
Kim Pal - 回复 分享
flashlight is very important for android user.We are providing best flashlight with different feature.You can visit flashlight with extra feature,download and enjoy it.
https://play.google.com/store/apps/detai...
flash light - 回复 分享
download best led torch light
flash light - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 53
总计 4,207
