跳转到主内容
LED圣诞灯LED更换
你所需要的
  1. LED圣诞灯LED更换, 发光二极管: 步骤 1 中的图像 1,1
    • “把多面的“灯泡”拿开。彩色灯罩断裂了——有些很硬,但它们确实出来了。他们不会拧螺丝。
  2. LED圣诞灯LED更换: 步骤 2 中的图像 1,2 LED圣诞灯LED更换: 步骤 2 中的图像 2,2
    • 拆卸LED及其插头。在我拥有的链条中,有两种不同的风格是不可互换的。
    • 请注意,插座是带钥匙的——它只能通过一种方式进入插座。
  3. LED圣诞灯LED更换: 步骤 3 中的图像 1,3 LED圣诞灯LED更换: 步骤 3 中的图像 2,3 LED圣诞灯LED更换: 步骤 3 中的图像 3,3
    • 从插头上拆卸损坏的LED,以便你可以重复使用插头。请注意,新的LED的一条腿比另一条长。
    • 长长的引线用钥匙进入插头的一侧,如图所示。
    • LED的灯泡可能不能完美地安装,但谁在乎呢,它就会在塑料多面灯泡盖下。
    • 弯曲铅并切割。
    • 如果你有“好”股的灯泡,试试灯泡。如果它有效,把它放在你的坏链中,看看这是否解决了问题。如果没有,你知道LED现在很好,所以继续下一个。
结论
要重新组装你的设备,请按逆序按照以下说明操作。
9等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Betty Lise
于02/03/13注册
728 声望
创作了2篇指南
13指南评论
Hi! Can you tell me the difference between the two types of light bases you show above? The situation I have is I bought a set of the clear LEDs figuring we could get replacements since my husband prefers the colored ones. But, once we started pulling them apart, we found the different sized bases and the only replacement ones I could find had the short stubby base. Are they interchangeable if we pull the bulb out of the base? Do you have any suggestions for us? Thanks for any help!
Patti - 回复
The reason for the two different size sockets is that if you look at your strand, every so many lights three wire come into the socket instead of two. I think (and this is only a hypothesis) than the shorter sockets are to allow room for the connection of the third wire. Why they didn't just use short sockets for everything I don't know. But it seems likely to me that the short one would work everywhere. I have not tried it.
Betty Lise -
Thanks so much for posting this guide! My outdoor light strings are far from waterproof and I live in a rainy climate (yes, even in December), so my original LEDs corroded badly and the strings stopped working.
I ordered a whack of replacement LEDs using the reference numbers you provided. Replacement was simple. The results were spectacular -- better than I had dared hope. For $10 and a few minutes work, I kept $200 worth of strings from getting tossed. Thanks a bunch!
Rudi - 回复
I've been using LED Christmas lights in many forms for a decade now, and I have NEVER seen replacement bulbs sold for any of them.
The rest of this I could have figured out on my own, but where do you get your replacement bulbs?
Dr H - 回复
Any tricks to getting the faceted lamp covers off - or back on (which is harder, in my experience)?
pfedorch - 回复
添加评论
浏览统计数据:
过去 24 小时: 75
过去 7 天: 750
过去 30 天: 3,449
总计 89,352
