跳转到主内容
LCD X2gen Display disassembly
你所需要的
  1. LCD X2gen Display disassembly, Display: 步骤 1 中的图像 1,1
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: 步骤 2 中的图像 1,1
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: 步骤 3 中的图像 1,1
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: 步骤 4 中的图像 1,1
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: 步骤 5 中的图像 1,1
    • Top middle
  6. LCD X2gen Display disassembly: 步骤 6 中的图像 1,1
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: 步骤 7 中的图像 1,1
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: 步骤 8 中的图像 1,1
    • This pic shows the left side
  9. LCD X2gen Display disassembly: 步骤 9 中的图像 1,2 LCD X2gen Display disassembly: 步骤 9 中的图像 2,2
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: 步骤 10 中的图像 1,1
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: 步骤 11 中的图像 1,2 LCD X2gen Display disassembly: 步骤 11 中的图像 2,2
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: 步骤 12 中的图像 1,1
    • Remove the data connector and ground.
    • Lift display. Is now completely free
结论
2等其他人完成本指南。
Aleks
于02/11/14注册
201 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 55
总计 2,022
