跳转到主内容
HP Photosmart 935 LCD Screen Replacement
你所需要的
  1. HP Photosmart 935 LCD Screen Replacement, Batteries: 步骤 1 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement, Batteries: 步骤 1 中的图像 2,2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 LCD Screen Replacement: 步骤 3 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Pull out the batteries.
  4. HP Photosmart 935 LCD Screen Replacement, Plastic Casing: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 LCD Screen Replacement: 步骤 6 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 LCD Screen Replacement: 步骤 7 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 LCD Screen Replacement: 步骤 8 中的图像 1,3 HP Photosmart 935 LCD Screen Replacement: 步骤 8 中的图像 2,3 HP Photosmart 935 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 LCD Screen Replacement: 步骤 10 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
  10. HP Photosmart 935 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 1,1
    • Orient the camera so that the LCD screen is facing you.
    • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
    • Removing the casing completely is crucial to completing this guide.
  11. HP Photosmart 935 LCD Screen Replacement: 步骤 12 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
  12. HP Photosmart 935 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
  13. HP Photosmart 935 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
    • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
  14. HP Photosmart 935 LCD Screen Replacement: 步骤 15 中的图像 1,1
    • Unplug the connected red and white wires. They will come out with the small white casing.
  15. HP Photosmart 935 LCD Screen Replacement: 步骤 16 中的图像 1,1
    • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
  16. HP Photosmart 935 LCD Screen Replacement: 步骤 17 中的图像 1,2 HP Photosmart 935 LCD Screen Replacement: 步骤 17 中的图像 2,2
    • Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
    • Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
结论
3等其他人完成本指南。
Nick Oleskowicz
于04/03/12注册
287 声望
创作了3篇指南
团队
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012 的会员
CPSU-FORTE-S12S15G13
5 名成员
创作了10篇指南
一条评论
Thank for this very good job, I own this this camera so it is will be quite easy to fix it following your guide.
Saverio Mercurio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 34
总计 2,425
