当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Power off and unplug your device before starting this repair.
Open the case carefully while loosing the marked srews.
Check the power-board. If there are any blown-up capacitors, you should replace them.
For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
Insert the replacement capacitors and solder it. Check the poles!
If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
取消:我没有完成这个指南。
9等其他人完成本指南。
与6其他贡献者
于01/18/13注册
561 声望
撰写一个指南
徽章: 8
+ 5更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 41
总计 13,345
