跳转到主内容
LCD LG 37LF65 Capacitor replacement
你所需要的
  1. LCD LG 37LF65 Capacitor replacement, Open the case: 步骤 1 中的图像 1,1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: 步骤 2 中的图像 1,1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: 步骤 3 中的图像 1,1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
结论
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9等其他人完成本指南。
eugl18
于01/18/13注册
561 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 32
总计 13,318
