跳转到主内容
Kyocera Zio M6000 Digitizer Replacement
你所需要的
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: 步骤 1 中的图像 1,2 Kyocera Zio M6000 Digitizer Replacement, Battery: 步骤 1 中的图像 2,2
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
  2. Kyocera Zio M6000 Digitizer Replacement: 步骤 2 中的图像 1,2 Kyocera Zio M6000 Digitizer Replacement: 步骤 2 中的图像 2,2
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: 步骤 3 中的图像 1,2 Kyocera Zio M6000 Digitizer Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
  4. Kyocera Zio M6000 Digitizer Replacement: 步骤 4 中的图像 1,2 Kyocera Zio M6000 Digitizer Replacement: 步骤 4 中的图像 2,2
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
  5. Kyocera Zio M6000 Digitizer Replacement: 步骤 5 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 5 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 5 中的图像 3,3
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
  6. Kyocera Zio M6000 Digitizer Replacement: 步骤 6 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 6 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 6 中的图像 3,3
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
  7. Kyocera Zio M6000 Digitizer Replacement: 步骤 7 中的图像 1,2 Kyocera Zio M6000 Digitizer Replacement: 步骤 7 中的图像 2,2
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
  8. Kyocera Zio M6000 Digitizer Replacement: 步骤 8 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 8 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 8 中的图像 3,3
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
  9. Kyocera Zio M6000 Digitizer Replacement: 步骤 9 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 9 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 9 中的图像 3,3
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: 步骤 10 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: 步骤 10 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: 步骤 10 中的图像 3,3
    • Remove the two rubber pieces from the ends of the panel.
  11. Kyocera Zio M6000 Digitizer Replacement: 步骤 11 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 11 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 11 中的图像 3,3
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
  12. Kyocera Zio M6000 Digitizer Replacement: 步骤 12 中的图像 1,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 12 中的图像 2,3 Kyocera Zio M6000 Digitizer Replacement: 步骤 12 中的图像 3,3
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
结论
2等其他人完成本指南。
Scott Nguyen
于09/16/15注册
522 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 345
