跳转到主内容
Kyocera QCP-2035 Microphone Replacement
你所需要的
  1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 步骤 1 中的图像 1,3 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 步骤 1 中的图像 2,3 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: 步骤 1 中的图像 3,3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Microphone Replacement: 步骤 2 中的图像 1,3 Kyocera QCP-2035 Microphone Replacement: 步骤 2 中的图像 2,3 Kyocera QCP-2035 Microphone Replacement: 步骤 2 中的图像 3,3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Microphone Replacement: 步骤 3 中的图像 1,3 Kyocera QCP-2035 Microphone Replacement: 步骤 3 中的图像 2,3 Kyocera QCP-2035 Microphone Replacement: 步骤 3 中的图像 3,3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Microphone Replacement: 步骤 4 中的图像 1,3 Kyocera QCP-2035 Microphone Replacement: 步骤 4 中的图像 2,3 Kyocera QCP-2035 Microphone Replacement: 步骤 4 中的图像 3,3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Microphone Replacement, Microphone: 步骤 5 中的图像 1,3 Kyocera QCP-2035 Microphone Replacement, Microphone: 步骤 5 中的图像 2,3 Kyocera QCP-2035 Microphone Replacement, Microphone: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the microphone at the bottom left corner of the phone.
    • using tweezers, Lift the microphone straight out of the phone.
结论
另外一个人完成了本指南。
cove
于01/21/15注册
116 声望
撰写一个指南
团队
USF Tampa, Team 5-3, Brown Winter 2015 USF Tampa, Team 5-3, Brown Winter 2015 的会员
USFT-BROWN-W15S5G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 250
