跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Kyocera Oystr,请使用我们的维修手册
  1. Kyocera Oystr Teardown, Removing the battery: 步骤 1 中的图像 1,3 Kyocera Oystr Teardown, Removing the battery: 步骤 1 中的图像 2,3 Kyocera Oystr Teardown, Removing the battery: 步骤 1 中的图像 3,3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: 步骤 2 中的图像 1,3 Kyocera Oystr Teardown, Removing screws from screen: 步骤 2 中的图像 2,3 Kyocera Oystr Teardown, Removing screws from screen: 步骤 2 中的图像 3,3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: 步骤 3 中的图像 1,3 Kyocera Oystr Teardown, Exposing internal components: 步骤 3 中的图像 2,3 Kyocera Oystr Teardown, Exposing internal components: 步骤 3 中的图像 3,3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: 步骤 4 中的图像 1,1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: 步骤 5 中的图像 1,3 Kyocera Oystr Teardown, Screen removal: 步骤 5 中的图像 2,3 Kyocera Oystr Teardown, Screen removal: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: 步骤 6 中的图像 1,1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
于10/04/11注册
24 声望
创作了2篇指南
团队
UW Stout, Team 5-7, Zhou Fall 2011 UW Stout, Team 5-7, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G7
2 名成员
创作了4篇指南
2条评论
where do I get a new screen?
LARS ANDERSEN - 回复
where do i get a new screen
thanks
LARS ANDERSEN - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 4,320
