跳转到主内容
Kyocera Marbl K127 Keyboard Replacement
你所需要的
  1. Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 1,3 Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 2,3 Kyocera Marbl K127 Keyboard Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 3,3
    • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  2. Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 步骤 2 中的图像 1,3 Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 步骤 2 中的图像 2,3 Kyocera Marbl K127 Keyboard Replacement, Remove the battery: 步骤 2 中的图像 3,3
    • Use your index finger at the top of the battery and pull it towards your body.
  3. Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 步骤 3 中的图像 1,3 Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 步骤 3 中的图像 2,3 Kyocera Marbl K127 Keyboard Replacement, Remove the phone backing.: 步骤 3 中的图像 3,3
    • Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
  4. Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 步骤 4 中的图像 1,3 Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 步骤 4 中的图像 2,3 Kyocera Marbl K127 Keyboard Replacement, Remove the existing keyboard.: 步骤 4 中的图像 3,3
    • Lift the motherboard away from you to locate the existing keyboard and remove it.
  5. Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 步骤 5 中的图像 1,3 Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 步骤 5 中的图像 2,3 Kyocera Marbl K127 Keyboard Replacement, Install the new keyboard.: 步骤 5 中的图像 3,3
    • Hold the new keyboard in your hand facing you as it would look in your cell phone, lift the motherboard with your opposite hand, and then flip the keyboard face down and fit it in to place.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 244
